material property setting?
I want to customized set the material's property in a 2D model. the material property is a function of position (coordinate-dependent).
e.g.
the conductivity in a 2D model changed through x-direction:
conductivity=f(x), x is the x-coordinate.
How to do that in comsol 4.2?
is there any example in model library?
Thank you very much
4 Replies Last Post 24.02.2014, 12:55 GMT-5
Posted: 1 decade ago 15.12.2011, 15:17 GMT-5
try it out, take a simple case i.e with a cylinder in 2D-axi, define a material conductivity as "sigma(z)" or for example:
sigma0 + sigma_slope * ( z - z0 ) / ( Ztop - Zbottom )
(since the axis in 2d-axi is along Z this should vary the conductivity along the axis), apply a constant current and check the voltage
here z0 is the starting point for z calculation, Ztop and Zbottom the Z coordinates of the cylinder top and bottom, hence the difference is the cylinder length
I believe this should work like that, I cannot check as I'm not now in front of my COMSOL WS ;)
Hi try it out, take a simple case i.e with a cylinder in 2D-axi, define a material conductivity as "sigma(z)" or for example: sigma0 + sigma_slope * ( z - z0 ) / ( Ztop - Zbottom ) (since the axis in 2d-axi is along Z this should vary the conductivity along the axis), apply a constant current and check the voltage here z0 is the starting point for z calculation, Ztop and Zbottom the Z coordinates of the cylinder top and bottom, hence the difference is the cylinder length I believe this should work like that, I cannot check as I'm not now in front of my COMSOL WS ;) -- Good luck Ivar
Posted: 1 decade ago 15.12.2011, 16:16 GMT-5
It works, Thanks a million!!!
Posted: 1 decade ago 17.04.2012, 08:02 GMT-4
Hi Ivar.
I want to model a material which its properties are varying according to the spatial coordinates (x, y, z). The material has temperature dependent properties. In COMSOL 4.2 how can I do this task? I am new in COMSOL and I need the detailed comments.
Regards.
Hi Ivar. I want to model a material which its properties are varying according to the spatial coordinates (x, y, z). The material has temperature dependent properties. In COMSOL 4.2 how can I do this task? I am new in COMSOL and I need the detailed comments. Regards.
Posted: 1 decade ago 24.02.2014, 12:55 GMT-5
I have the same problem but I can't fix it by using the same procedure.
I have a 2D rectangle and I want to change the thermal conductivity along the x axis as a function of x.
I changed the predefined thermal conductivity with both expressions: "k(x)" and "k0+k_slope*(x-x0)/(xinitial-xfinal)". when I used the second one I also defined in Model->Definitions k0, k_slope, xinitial and xfinal but it doesn't work.
Am I missing something? Do I have to define anything else?
Thank you very much for your help,
Edoardo
Hello, I have the same problem but I can't fix it by using the same procedure. I have a 2D rectangle and I want to change the thermal conductivity along the x axis as a function of x. I changed the predefined thermal conductivity with both expressions: "k(x)" and "k0+k_slope*(x-x0)/(xinitial-xfinal)". when I used the second one I also defined in Model->Definitions k0, k_slope, xinitial and xfinal but it doesn't work. Am I missing something? Do I have to define anything else? Thank you very much for your help, Edoardo
