Power and current calculation in Joule Heating Model
Hi all,
I´m trying to check the power dissipated in my model by two different methods:
1 - Directly calculating volume int (tem.Qh) = 4.7409W
2 - By calculating the inward current in the input surface (9) and multiplying by the voltage input (0.2V). In this case, the result is 19.80*0.2 = 3.9604
Shoudn´t these two be the same?
Besides that, the sum of the inward (9) and outward (1) current should be zero, but that is not the case (0.7126A).
What I´m doing wrong?
Thanks in advance,
Andre
1 Reply Last Post 08.12.2011, 02:49 GMT-5
Posted: 1 decade ago 08.12.2011, 02:49 GMT-5
Have you tried to refine your mesh to see the change of results ?
Best rgds,
Dinh
Hi, Have you tried to refine your mesh to see the change of results ? Best rgds, Dinh
