Global Variable using Local Variable
I want to define a global variable using some local variables which were computed by the simulation. How can I do that.
Thank you.
3 Replies Last Post 29.10.2019, 03:41 GMT-4
Posted: 5 years ago 24.10.2019, 07:52 GMT-4
Updated: 5 years ago 24.10.2019, 05:35 GMT-4
Use Components->Definitions->Component Couplings (from version 5.5: Components->Definitions->Nonlocal Couplings) to add a coupling operator from whatever place you wish to have something available globally. An Integration operator is commonly used for this, but the other operators are also useful depending on your needs.
You can use the generated operator where you wish to use it since they are global.
Note that there are other nonlocal couplings available that "copies" data from one part of the model to another part.
Lars Gregersen
Comsol Denmark
Use **Components->Definitions->Component Couplings** (from version 5.5: **Components->Definitions->Nonlocal Couplings**) to add a coupling operator from whatever place you wish to have something available globally. An Integration operator is commonly used for this, but the other operators are also useful depending on your needs. You can use the generated operator where you wish to use it since they are global. Note that there are other nonlocal couplings available that "copies" data from one part of the model to another part.
Posted: 5 years ago 28.10.2019, 19:41 GMT-4
Updated: 5 years ago 28.10.2019, 15:42 GMT-4
Hello, Lars. What is this "version 5.5" of which you speak? :-)
Posted: 5 years ago 29.10.2019, 03:41 GMT-4
Updated: 5 years ago 29.10.2019, 04:23 GMT-4
Hi Robert,
That is the version to be released soon. Those who visited the user conferences already have a pre-release.
From version 5.5, this menu entry has changed its name in order to make it more clear what you will actually find under it.
Henrik
Henrik Sönnerlind
COMSOL
Hi Robert, That is the version to be released soon. Those who visited the user conferences already have a pre-release. From version 5.5, this menu entry has changed its name in order to make it more clear what you will actually find under it. Regards, Henrik
