rotation
In 3D model and one part suppose rotating by 100 rpm. then how to give this on boundary ?
3 Replies Last Post 10.12.2011, 07:16 GMT-5
Posted: 1 decade ago 02.12.2011, 03:30 GMT-5
Most often i.e. in solid you leave the body "rigid" and rotate the frame around, i.e. apply a centrifugal body load
F = rho*omega^2*R
where R = sqrt(x^2+y2) in 2D and omega = 2*pi*rmp/60 in [rad/s]
Hi Most often i.e. in solid you leave the body "rigid" and rotate the frame around, i.e. apply a centrifugal body load F = rho*omega^2*R where R = sqrt(x^2+y2) in 2D and omega = 2*pi*rmp/60 in [rad/s] -- Good luck Ivar
Posted: 1 decade ago 10.12.2011, 07:16 GMT-5
What model should one use?
Hi, What model should one use?
