Adding interval from geometry toolbar
I am modelling the electrochemical impedance of a 1D li-ion battery, and would like to know how to add interval from the geometry toolbar. I am going through the tutorials by COMSOL for modelling impedance, but the geometry toolbar does not have "interval" in it.
1 Reply Last Post 31.07.2019, 16:32 GMT-4
Posted: 5 years ago 31.07.2019, 16:32 GMT-4
Updated: 5 years ago 31.07.2019, 16:32 GMT-4
Hello Amit,
If you can update your installation to 5.4, you will find "Interval" in the Geometry toolbar when your geometry is 1D.
I don't have older versions on my machine to check if it was there at 5.3, but at least you can access the same functionality through the Model Builder by right-clicking on the Geometry node.
Jeff Hiller
Hello Amit, If you can update your installation to 5.4, you will find "Interval" in the Geometry toolbar when your geometry is 1D. I don't have older versions on my machine to check if it was there at 5.3, but at least you can access the same functionality through the Model Builder by right-clicking on the Geometry node. Best regards, Jeff
