Parametric Sweep with Heat Transfer - Initial Values
Hi all,
I am simulating the heat transfer into a plate with a section of the plate shrinking with time. I would like to perform a parametric sweep that uses defined initial temperature values for the first time-dependent sweep, and then uses the last temperature values from the first sweep as initial values for the second sweep, and so on. How do I specify my COMSOL simulation to use initial values for the first sweep only?
Thank you in advance!
Jan Vincent Carag
Jan Vincent Carag
Undergraduate Researcher
Artie McFerrin Department of Chemical Engineering
vincentcarag@tamu.edu
0 Replies Last Post 24.07.2019, 20:20 GMT-4
Hello Vincent Carag
