Plots do not get updated in .avi animation export
Posted 03.07.2019, 12:01 GMT-4 Electromagnetics, Low-Frequency Electromagnetics, Results & Visualization Version 5.4 0 Replies
Hello everyone
I am new to COMSOL and I want to simulate the penetration of a magnetic field into a coil core which is highly permeable and conductive. In order to do so I created the model in the attachment and tried to create an animated .avi file for the magnetic flux magnitude and the current density magnitude.
I simulate 200seconds and I want to have the animation run at 50Hz.
The first animation of the magnetic flux density runs smoothly at 50Hz when I export the .avi file in Comsol.
However, when I try to create a .avi file for the currenty density magnitude with the same export settings as the flux magnitude, the animation only seems to update the frame every 20 frames or so. (When I display the time variable t, the time variable displayed on the top axis gets updated but it seems like for some reason, the surface plot does not get updated according to time).
Any ideas what I could do to resolve this issue?
Thanks very much!
Hello Denis v.A.
