Edgar J. Kaiser
Certified Consultant
5 years ago
03.06.2019, 07:43 GMT-4
Updated:
5 years ago
you may want to check the documentation about the 3D interpolation function. This allows to use spatially distributed material properties.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
5 years ago
07.06.2019, 06:00 GMT-4
Hi Kaiser
I have checked the documentation and prepared my import file accordingly. So is there any way I can check the cordinates of import file with the geometry. The problem is model data and measured domain data is with different resolution. Even if I upsample the data according to the model but still I am getting this error.
Undefined variable.
- Variable: sigma11
- Geometry: geom1
- Domain: 32
Failed to evaluate variable.
- Variable: comp1.ec.sigmaxx
- Defined as: sigma11
- Variable: comp1.ec.Jix
- Defined as: (((comp1.ec.sigmaxxcomp1.ec.Ex)+(comp1.ec.Eycomp1.ec.sigmaxy))+(comp1.ec.Ezcomp1.ec.sigmaxz))
- Variable: comp1.ec.Jx
- Defined as: comp1.ec.Jix
- Expression: d(((comp1.ec.Jxtest(comp1.Vx)+comp1.ec.Jytest(comp1.Vy)+comp1.ec.Jztest(comp1.Vz))comp1.ec.d)(dvol),{test@4})
The domain 32 is white matter and sigma11 is the first row first column of tensor matrix. Please let me know if you have any further suggestion or need any information. I feel its not difficult but can't able to connect dots.
TIA
Nitish
Hi Kaiser
Undefined variable.
- Variable: sigma11
- Geometry: geom1
- Domain: 32
- Defined as: (((comp1.ec.sigmaxx*comp1.ec.Ex)+(comp1.ec.Ey*comp1.ec.sigmaxy))+(comp1.ec.Ez*comp1.ec.sigmaxz))
- Expression: d(((comp1.ec.Jx*test(comp1.Vx)+comp1.ec.Jy*test(comp1.Vy)+comp1.ec.Jz*test(comp1.Vz))*comp1.ec.d)*(dvol),{test@4})
TIA
Nitish
Edgar J. Kaiser
5 years ago
07.06.2019, 12:01 GMT-4
Did you assign the interpolation function to the conductivity in the respective material node or in the physics node?
Edgar J. Kaiser
www.emphys.com
5 years ago
10.06.2019, 00:16 GMT-4
I assigned it in Physics node using the current conservation option.
So process I am using is firstly make a text file with 9 columns. The first 3 are coordinates and next six are the data. Define a global interpolation variable with 6 different function names inside it.
Use the physics node of current conversation and assign the user defined anisotropic conductivity with the similar function names written in global interpolation variable.
