Regarding Mesh formation
How to create a mesh in nanolevel layer of a structural material i am analysing?
1 Reply Last Post 03.06.2019, 06:43 GMT-4
Posted: 6 years ago 03.06.2019, 06:43 GMT-4
You can try different options for mesh formation. You can start with Physics-controlled mesh from sequence type and then choose Normal element size. If you are not satisfied with your results, then you can choose the element size to be finer.
If none of them works then you can manually define your mesh by selecting user-defined mesh under sequence type. This will require some knowledge on mesh creation, following the documentation will be helpful.
You can try different options for mesh formation. You can start with Physics-controlled mesh from sequence type and then choose Normal element size. If you are not satisfied with your results, then you can choose the element size to be finer. If none of them works then you can manually define your mesh by selecting user-defined mesh under sequence type. This will require some knowledge on mesh creation, following the documentation will be helpful.
