Differential (multielement) lumped ports in RF module
I am using the differential (multielement Lumped ports) ports of the RF module to run an S-parameter analysis on a couple of differentiaol traces on a PCB.
Under Settings the reference characteristic impedance is set as Zref = 50 Ohm. Is that a differential or single-ended reference impedance?
I am doing a port and frequency sweep to save the S-parameters over frequency. Are saved S-parameters differential?
Thank You
0 Replies Last Post 06.05.2019, 12:13 GMT-4
Hello Mauricio Yañez
