em change due to mechanical deformation
An em wave deforms a solid, say a copper plate. Deformed copper plate in turn changes em characteristics.
Any idea how to approach this?
Thanks.
--Arthur Rupel
1 Reply Last Post 22.10.2011, 03:32 GMT-4
Posted: 1 decade ago 22.10.2011, 03:32 GMT-4
couple the two, with a Multiphysics programme like COMSOL :)
Add two physics solid and ACDC and connect the BC correctly.
The term correctly means that you take some time to sketch out the interactions and get your BC linked corectly. There are a few models (not exactly your case but close) in the model library
Hi couple the two, with a Multiphysics programme like COMSOL :) Add two physics solid and ACDC and connect the BC correctly. The term correctly means that you take some time to sketch out the interactions and get your BC linked corectly. There are a few models (not exactly your case but close) in the model library -- Good luck Ivar
