Setting last time step as initial conditions of next thermal model run
Posted 25.03.2019, 15:32 GMT-4 Studies & Solvers Version 5.3a 1 Reply
I've been trying to create long time scale thermal models (2000yr+) by running them in 100 year segments and using the final time step to start the next 100 year run, saving each 100 year run in its own file. For some reason using the final time step of a 100 year run (with 1 day steps) produces the following error:
There are 53046 void equations (empty rows in matrix) for the variable comp1.ht.dt2Inv_T. at coordinates: (64.0549,-0.0610404), (62.5617,-1.55478), (62.5627,-4.54318), (64.056,-59.9383), (62.5614,-58.4453), ... and similarly for the degrees of freedom (empty columns in matrix). Last time step is not converged.
If I run the model for only 60 days it has no problem using the final time step for the next set of 60 days and I can repeat the process for as many times as I would like.
Currently I have it structured to delete all but the final time step from the previous solution by using "combine solution" to save memory and speed it up, this is not an issue for the 60 day model.
Does anybody have an idea as to how I can fix this? I've been having this issue for weeks.
Thanks!
