Using a stationary solution for time-dependent problem
I have solved a stationary model for a flow field and temperature distribution.
In the next step I want to solve a time-dependent problem for mass transport. In the inlet there's a change from substance A to substance B. The substances are completly the same in their physical properties, the only thing that changes is its name. It's for calculating a residence time distribution.
So my question is: Is it possible to solve only for the time-dependent mass transport, without solving for the flow field and temperature, because they a same as in the stationary solution? I think this should reduce the amount of time required for the solution....
Thanks in advance! Till
3 Replies Last Post 25.03.2019, 05:12 GMT-4
Posted: 6 years ago 21.03.2019, 10:16 GMT-4
I never did this, but in study steps, you can choose to simulate certain physics; e.g. only calculate the heat transfer module, or in your case, calculate for the mass transport case.
You should use the solution of the steady-state as an initial condition for the flow and temperature field to make this work.
Good luck and hope this helped.
-Marvin
I never did this, but in study steps, you can choose to simulate certain physics; e.g. only calculate the heat transfer module, or in your case, calculate for the mass transport case. You should use the solution of the steady-state as an initial condition for the flow and temperature field to make this work. Good luck and hope this helped. -Marvin
Posted: 6 years ago 25.03.2019, 04:04 GMT-4
I use steady-state flow field in the time dependent mass transfer problem. First, calculate only the fluid dynamics at steady-state. Then use it as the convection term in the Transport of Diluted Species node by selecting the velocity field "spf". Activate only "spf" node at steady-state and "tds" in time dependent study.
BR Lasse
I use steady-state flow field in the time dependent mass transfer problem. First, calculate only the fluid dynamics at steady-state. Then use it as the convection term in the Transport of Diluted Species node by selecting the velocity field "spf". Activate only "spf" node at steady-state and "tds" in time dependent study. BR Lasse
Posted: 6 years ago 25.03.2019, 05:12 GMT-4
Thank you!
I'll try it...
Thank you! I'll try it...
