Far-field radiation pattern of an optical waveguide
Dear forum users,
I would like to calculate the far field diffraction pattern resulting from a guided mode in an optical waveguide.
My specific example: light is guided in the core of a photonic crystal fiber, reaches the end and gets diffracted into free space. How does the pattern look in the far field (or at a certain distance z away from the fiber).
I know how to calculate the mode with a Boundary Mode analysis study. But this gives me only the near-field at a cross section of the fiber (which is supposed to be infinitely long for the boundary mode analysis).
Is there a way to transform this near-field calculation into far-field?
Thanks a lot
Patrick
3 Replies Last Post 11.10.2011, 12:14 GMT-4
Posted: 1 decade ago 11.10.2011, 10:01 GMT-4
you can add the 'far-field' domain node under the 'Electromagnetic Waves' node. This makes far field variables available.
However, far field is the pattern at infinity, not a certain distance.
And a warning: plotting the far field in 3D displays is very time consuming, often much more than solving the system. I would recommend to use classical Azimuth/Elevation (1D) polar plots for that. They are fast.
Cheers
Edgar
Hi, you can add the 'far-field' domain node under the 'Electromagnetic Waves' node. This makes far field variables available. However, far field is the pattern at infinity, not a certain distance. And a warning: plotting the far field in 3D displays is very time consuming, often much more than solving the system. I would recommend to use classical Azimuth/Elevation (1D) polar plots for that. They are fast. Cheers Edgar
Posted: 1 decade ago 11.10.2011, 10:50 GMT-4
Dear Edgar,
thanks for the reply. However, I am not using 3D modelling but 2D. Does it work there as well?
Best
Patrick
Dear Edgar, thanks for the reply. However, I am not using 3D modelling but 2D. Does it work there as well? Best Patrick
Posted: 1 decade ago 11.10.2011, 12:14 GMT-4
I haven't tried 2D so far but one mouseclick shows you that the far field domain is available in 2D as well.
