scaling of variables
Posted 09.10.2011, 18:00 GMT-4 Fluid & Heat, Studies & Solvers Version 4.2 7 Replies
What should be chosen for scaling of variables from "manual, initial value based, automatic, none"?
Thanks for the help.
Sirisha.
See COMSOL Multiphysics Reference Guide, Version 4.2, pages 449, 452-453.
in 99.9% of the cases I use the default settings of Comsol, it's only when I add my own physics that I analyse fist once coarsly, then apply a manual scale to get the items down to around 1
In general, for me, >90% of the time COMSOL, all defaults are OK
For example, if V is of the order of 1 nanovolt across the model, then I would enter 1e-9.
(However, I just tried a simple model, and set the scales to 1e100 or 1e-100, and this didn't affect the solution at all. Maybe because it is such a small model...)
(I happened to notice that Comsol guesses scales very poorly in some cases, so decided to investigate whether this was the source of the problems with my model.)
What you posted is really helpful. I just have a question, how does this manual scaling method compares with dimensionless method(i.e. I define a characteristic time and length and then make the all variables units to 1 )?
Any reply is appreciated!
Best Regards,
Leo
I typically use the COMSOL default value for a model that I do not expect to solve repeatedly or to help me determine what scaling factor I may want to choose. However, if I solve a model routinely, I want to manually adjust the scaling factor in order to help on convergence rates, and solve the model quicker. I do not know the exact algorithm that COMSOL uses to determine the scaling factors automatically, but it appears to use the maximum value of the variable over the 1st iteration, then adjust for the 2nd iteration. Perhaps I should read the manual and learn more about the automatic method.
I look at scaling as a lot like the choice of values to use when you non-dimensionalize the equation system. I like to use values that I might use as boundary conditions for a starting point. For example, a good scaling for Navier-Stokes equations is the inlet velocity, and exit pressure, and inlet temperature. The idea being to scale the variables to a nominal range where the absolute value is 0-1.
Some variables are tougher to scale than others; particularly if they rely on a length scale. There are sometimes multiple length scales in a problem.
Hope this helps.
Thank you so much for your reply!
I also found an interesting thing when using scaling: when the variable changes its sign over time like from
-10^(-9) to 10^(-9), the scaling value 10^(-9) seems can handle this problem.
I really agree that scaling is important in convergence. In my mind, the default setting of comsol often can not give you a satisfactory convergence...
Best Regards,
Leo
I recently tested an example, its results show that by only change the manual scaling value could change both the divergence and the solution.
Could you please advice?
Many thanks!
Best Regards,
Leo
Suggested Content
- KNOWLEDGE BASE Manually Setting the Scaling of Variables
- FORUM Manual Scaling
- BLOG Solving Linear Static Finite Element Models
- FORUM Variables Scaling
- BLOG Designing New Structures with Shape Optimization
