Electrostatics on a thermally expanded or contracted model
Good mornign everyone,
I am currently investigating the electric field distribution on a cable termination and would like to perform the following analysis:
  • Calculation of electric field at initial state (Electrostatics)
  • Thermal expansion of the model at different temperatures (Heat transfer in solids plus Solid Mechanics physics)
  • Calculation of electric field at expanded state (Electrostatics with initial condition taken from the thermal expansion study)
Currently, I don't think that there is a link between the thermal expansion model and the electrostatics one, so I am wondering if someone has any experience at this kind of modeling.
Thanks in advance for your responses.
Kind regards,
Pavlos.
4 Replies Last Post 18.03.2019, 05:33 GMT-4
Posted: 6 years ago 08.03.2019, 09:02 GMT-5
Hi Pavlos,
I guess the most straightforward solution is to add a moving mesh and control the mesh deformation with the deformation from the thermal-structural physics.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Pavlos, I guess the most straightforward solution is to add a moving mesh and control the mesh deformation with the deformation from the thermal-structural physics. Cheers Edgar
Posted: 6 years ago 08.03.2019, 09:24 GMT-5
Hi Edgar,
Thanks for the advice. Actually I found a guide on how to do that and I am following that one at the moment.
Please find a link here: https://www.comsol.de/blogs/how-to-reuse-a-deformed-shape-as-a-geometry-input/
I believe the other option is you said, using ALE with solid mechanics and electrostatics.
Thanks for your time.
Kind regards,
Pavlos.
Hi Edgar, Thanks for the advice. Actually I found a guide on how to do that and I am following that one at the moment. Please find a link here: https://www.comsol.de/blogs/how-to-reuse-a-deformed-shape-as-a-geometry-input/ I believe the other option is you said, using ALE with solid mechanics and electrostatics. Thanks for your time. Kind regards, Pavlos.
Posted: 6 years ago 08.03.2019, 12:04 GMT-5
Pavlos,
yes the manual procedure in the blog should work as well. With the ALE you can achieve a fully coupled and dynamic procedure.
Good luck Edgar
Edgar J. Kaiser
www.emphys.com
Pavlos, yes the manual procedure in the blog should work as well. With the ALE you can achieve a fully coupled and dynamic procedure. Good luck Edgar
Posted: 6 years ago 18.03.2019, 05:33 GMT-4
Hi Edgar,
Thank you very much for the advice.
I will try it both ways to identify the one that suits my case best. (By using the guide, I get some errors that the mesh is problematic in some cases)
Kind regards,
Pavlos.
Hi Edgar, Thank you very much for the advice. I will try it both ways to identify the one that suits my case best. (By using the guide, I get some errors that the mesh is problematic in some cases) Kind regards, Pavlos.
