26.09.2011, 10:21 GMT-4
if I read you correctly you want only to deform your mesh, and then run a simulation from scratch on the new mesh.
I believe this is possible by imposing a first stationary study with a described deformation. Then to save the geometry via old mesh) for a new simulation. This was possible in 3.5 so why not also v4 ?
If you keep it as 2 coupled solid solutions you have some stress buildup from the initial deformation that is probably not what you want. One would have to find back the "save mesh as geoemtry" command for the second run.
I cannot guaranty I'll find it back but will make it a try
29.09.2011, 17:15 GMT-4
Thanks a lot Ivar.
For now I managed to do it by exporting the mesh file and runing a matlab script on it to introduce the displacement.
It seemed to be the most straight forward solution for me eventhough it took a bit of time to do it correctly. Fortunately the displacement I introduce is just a fraction of the element size and the distortion doesn't seem to be a problem for comsol so far.
Thanks again.
Thanks a lot Ivar.
Thanks again.
José Mauricio Urbano Caguasango
24.09.2012, 12:14 GMT-4
Hi! I am actually facing a similar problem. I am running a structural mechanics simulation on Matlab. I want to use the deformed mesh on the next iteration, could you help me to get the right code? I am trying with the commands getVertex and setVertex, but it seems that I am getting always the same output (This means that my script is not recognizing my new mesh).
Thanks!
Thanks!
24.09.2012, 12:16 GMT-4
Thanks!
Thanks!
25.09.2012, 11:16 GMT-4
when I performed this I actually wrote a script in matlab to change the values of the coordinates of each node of the domain of interest. But I did it by exporting the COMSOL mesh in a txt file and running the script on it.
I admit it is not smartest choice. But it worked. If you want I can send you the script, maybe with an example, but if your model is big it might take long to run.
I believe it is possible to do this operation using the deformed mesh node. Probably you would have to tell COMSOL to apply the other physics with respect to the reference frame of the deformed mesh. I'll try it later and if I manage to make it work I let you know.
Regards
Regards
25.09.2012, 11:49 GMT-4
Hi again,
I tryied it in an extremelly simple fashion, just add the 'moving mesh' node to the simulation, impose a mesh displacement, and solve. No changes in any equation or anything. It works. The solution is clearly calculated for the deformed geometry, as it is expected.
I also tryied the node 'deformed geometry', and also this one works. I believe this is just a less complete version of the moving mesh.
I attached the file I used to check it.
Usually I work in electromagnetics, so the example is an AC DC model.
Hope it helps somehow.
Hi again,
