Line/Marker style cycling
The below post is related to an archived discussion
Hi All,
Good to see that version 5.4 allows for colour cycling definition using customised text files. I would like to do the same with the Line styles, (dotted, dashed, dot-dash etc...), but I cannot find instructions or any obvious text file in the installation directory that I can customise for this purpose.
Am I missing something? The combo box selection for line style allows a "cycle (reset)" option, but I cannot find how to implement it!
Thanks for any pointers...
2 Replies Last Post 31.01.2019, 02:59 GMT-5
Posted: 6 years ago 31.01.2019, 02:55 GMT-5
It's only the color cycle that can be customised by the user, not line styles. I have noted this as a suggestion to be considered for future releases.
The "Cycle (reset)" option resets the cycle state for each plot in a plot group. It can be used to synchronize e.g. colors and line styles between plots. E.g., suppose that you have a 1D plot group containing two line graphs, each each plotting a set of lines corresponding to a set of times or parameter values.
It's only the color cycle that can be customised by the user, not line styles. I have noted this as a suggestion to be considered for future releases. The "Cycle (reset)" option resets the cycle state for each plot in a plot group. It can be used to synchronize e.g. colors and line styles between plots. E.g., suppose that you have a 1D plot group containing two line graphs, each each plotting a set of lines corresponding to a set of times or parameter values.
Posted: 6 years ago 31.01.2019, 02:59 GMT-5
Hi Gunnar,
OK, I see what the functionality is now... thanks for clarifying!
Mark
Hi Gunnar, OK, I see what the functionality is now... thanks for clarifying! Regards, Mark
