Henrik Sönnerlind
COMSOL Employee
6 years ago
22.01.2019, 03:43 GMT-5
For cloth (and other thin layers with negligible bending stiffness), you need to use the Membrane interface.
However, be warned: It is difficult to obtain convergence in such models, since in real life wrinkles tend to develop unless the two in-plane principal stresses are positive everywhere. A geometrically nonlinear analysis with some initial stress which induces tension in the first iterations is a minimum requirement.
Henrik
Henrik Sönnerlind
COMSOL
Henrik
6 years ago
23.01.2019, 06:49 GMT-5
Thank you so much!
Can I use shell interface instead considering membrane is so hard to converge?
What I am modeling is an airtight cloth with inner pressure inside.
The idea is to set a prescribed distance at its center to get its corresponding reaction force.
I've attached 2 screen shots below.
Thanks in advance,
Ke Wu
Thank you so much!
Thanks in advance,
Ke Wu
Henrik Sönnerlind
COMSOL Employee
6 years ago
25.01.2019, 02:17 GMT-5
You can use the Shell interface. The reason not to do that is that as the bending stiffness gets smaller, the numerics gets more and more ill-conditioned. But as long as the solver does not throw warnings or errors at you, a shell solution will work. Due to the bending stiffness there will be no tendency to wrinkling.
Henrik
Henrik Sönnerlind
COMSOL
Henrik
