How to limit the range of dependent variable?
I want to solve the PDE in comsol in the special range for dependent variable. For example, the dependent variable,i.e., the concentration c is limited to c<=0.2 in the PDE, how to do?
2 Replies Last Post 17.01.2019, 04:31 GMT-5
Posted: 6 years ago 17.01.2019, 02:41 GMT-5
There seems no option for this, but you might use penalty approach to achieve it.
ZHANG, Pu
School of Physics,
Huazhong University of Science and Technology
Posted: 6 years ago 17.01.2019, 04:31 GMT-5
There is no direct way for setting an upper limit. You can however set a lower limit using by adding a Lower Limit node to a segregated solver. If you can reformulate your problem, that may be an option.
Henrik
Henrik Sönnerlind
COMSOL
Hi, There is no direct way for setting an upper limit. You can however set a lower limit using by adding a **Lower Limit** node to a segregated solver. If you can reformulate your problem, that may be an option. Regards, Henrik
