Slice plot single slice animation not working properly
Hello, all.
I'm using my school's license for COMSOL 5.2 to try to model a gas valve injecting gas into a vacuum chamber. I'm doing a simple model based on two cylinders, one on top of the other. The top cylinder is a thin capillary that gas will flow through. The bottom cylinder is the vacuum chamber.
I don't have a proper cfd module, so I'm trying to get around the problem using the "Transport of Diluted Species" module. I've set the initial concentration to zero for the two cylinders. The top of the top cylinder is set to some concentration, and the bottom of the bottom cylinder is set to 0. I get it to run just fine, but I am having problems getting at the data.
For the time-dependent study, I'm able to see the default 5-slice slice plot of gas concentration, and this works fine. I can watch the gas go from the "reservoir" to the vacuum chamber by using the animation tool. I see the general shape of the cloud across the different slices, but I want to view only central slice. However, if I set the number of slices to 1, the gas will never leave the top cylinder.
I've also gone through this same exercise going down the 2D modelling route. In that case, I got the same results as when I went for a single slice on the 3D modelling route.
0 Replies Last Post 02.01.2019, 14:55 GMT-5
Hello Levon McQuown
