2D flow solution plots
Posted 09.09.2011, 02:01 GMT-4 Version 4.2 5 Replies
I had posted a couple of days ago about modeling a microfluidic channel with 2D flow through it.
The channel is created in a plastic cube and the cube is bonded on to a thin glass plate.
The plate is heated from below by a metallic strip and I would like to see the temperature profile across the fluid
(first stationary, then time dependent).
No matter what boundary conditions I impose, I get an error saying no solution could be found and I see that the plots are unrealistic.
I have checked the geometry and the material properties and they are okay.
How can I couple the heat flow from the source with the fluid flow?
Can you suggest any other corrections?
5 Replies Last Post 13.09.2011, 10:40 GMT-4
