Importing gas-reaction kinetics data in CHEMKIN format
I have a problem importing gas-reaction kinetics data in CHEMKIN format. Specifically I found that TROE and LOW key words used in CHEMKIN seem not to be well interpreted in COMSOL, even if the release notes of COMSOL 3.3a specifically say that the CHEMKIN import pannel in the reaction engineering module supports them (I am using COMSOL 4.2). In particular I am having problem with this reaction
2OH(+M)<=>H2O2(+M) 7.400E+13 -.370 .00
LOW / 2.300E+18 -.900 -1700.00/
TROE/ .7346 94.00 1756.00 5182.00 /
H2/2.00/ H2O/6.00/
which is not interpreted as in CHEMKIN. I wrote manually the reaction rates and I solved the problem, but it is a rather annoying process... Has anybody had this problem?
Alberto
7 Replies Last Post 14.04.2015, 11:09 GMT-4
Hello Alberto Amato
Posted: 1 decade ago 01.10.2011, 21:35 GMT-4
just a follow-up to my post: I sent an e-mail to the COMSOL support: they confirmed that the CHEMKIN import utility has some bugs that prevent it to correctly interpret pressure dependent reaction rates. A fix to this bug should be available in future updates this fall.
Posted: 1 decade ago 15.10.2013, 07:59 GMT-4
I am wondering if you've find a way to avoid this error when importing CHEMKIN format kinetic and thermodynamic data?
now I have the same problem with 4.3b version. I've imported CHEMKIN format of reactions and species thermodynamic input data. When it comes to calculate rate constants for reactions that involve third part, th efunction changes to something strange. For instance if the reaction is H+HCO(+M)<=>CH2O(+M), naming the species as H= s7, CHO= s2, CH2O= s6, and M is the third part element (AR), also we have the value of the Arrhenius expressions : Forward frequency factor = A_f, forward temperature exponent: nf , forward activation energy: Ef
then it gives a forward rate constant as following!!
1.35E12*exp(-Ef_36/(R_const*T))*exp(-5962.2/(R_const*T))*(0.7*c_s1+c_s2+2*c_s3+c_s4+c_s5+c_s6+c_s7+c_s8+c_s9+c_s10+c_s11+c_s12+2*c_s13+c_s14+c_s15+c_s16+c_s17+2*c_s18+3*c_s19+6*c_s20+c_s21+c_s22+c_s23+1.5*c_s24)*10^(log10(exp(-1.5220700152207003E-4*T)+0.7824*exp(-3.629764065335753E-4*T)+0.21760000000000002*exp(-T/271))/(1+(-0.4+log10(1.35E12*T^(-2.57-nf_36)*exp(-5962.2/(R_const*T))*(0.7*c_s1+c_s2+2*c_s3+c_s4+c_s5+c_s6+c_s7+c_s8+c_s9+c_s10+c_s11+c_s12+2*c_s13+c_s14+c_s15+c_s16+c_s17+2*c_s18+3*c_s19+6*c_s20+c_s21+c_s22+c_s23+1.5*c_s24)*exp(Ef_36/(R_const*T))/Af_36)-0.67*log10(exp(-1.5220700152207003E-4*T)+0.7824*exp(-3.629764065335753E-4*T)+0.21760000000000002*exp(-T/271)))^2/(0.75-0.14*(-0.4+log10(1.35E12*T^(-2.57-nf_36)*exp(-5962.2/(R_const*T))*(0.7*c_s1+c_s2+2*c_s3+c_s4+c_s5+c_s6+c_s7+c_s8+c_s9+c_s10+c_s11+c_s12+2*c_s13+c_s14+c_s15+c_s16+c_s17+2*c_s18+3*c_s19+6*c_s20+c_s21+c_s22+c_s23+1.5*c_s24)*exp(Ef_36/(R_const*T))/Af_36)-0.67*log10(exp(-1.5220700152207003E-4*T)+0.7824*exp(-3.629764065335753E-4*T)+0.21760000000000002*exp(-T/271)))-1.27*log10(exp(-1.5220700152207003E-4*T)+0.7824*exp(-3.629764065335753E-4*T)+0.21760000000000002*exp(-T/271)))^2))*exp(Ef_36/(R_const*T))/((1+1.35E12*T^(-2.57-nf_36)*exp(-5962.2/(R_const*T))*(0.7*c_s1+c_s2+2*c_s3+c_s4+c_s5+c_s6+c_s7+c_s8+c_s9+c_s10+c_s11+c_s12+2*c_s13+c_s14+c_s15+c_s16+c_s17+2*c_s18+3*c_s19+6*c_s20+c_s21+c_s22+c_s23+1.5*c_s24)*exp(Ef_36/(R_const*T))/Af_36)*T^2.57)
I appreciate if someone could guide of a way to solve this problem.
Regardsm,
Zari
Hi, I am wondering if you've find a way to avoid this error when importing CHEMKIN format kinetic and thermodynamic data? now I have the same problem with 4.3b version. I've imported CHEMKIN format of reactions and species thermodynamic input data. When it comes to calculate rate constants for reactions that involve third part, th efunction changes to something strange. For instance if the reaction is H+HCO(+M)CH2O(+M), naming the species as H= s7, CHO= s2, CH2O= s6, and M is the third part element (AR), also we have the value of the Arrhenius expressions : Forward frequency factor = A_f, forward temperature exponent: nf , forward activation energy: Ef then it gives a forward rate constant as following!! 1.35E12*exp(-Ef_36/(R_const*T))*exp(-5962.2/(R_const*T))*(0.7*c_s1+c_s2+2*c_s3+c_s4+c_s5+c_s6+c_s7+c_s8+c_s9+c_s10+c_s11+c_s12+2*c_s13+c_s14+c_s15+c_s16+c_s17+2*c_s18+3*c_s19+6*c_s20+c_s21+c_s22+c_s23+1.5*c_s24)*10^(log10(exp(-1.5220700152207003E-4*T)+0.7824*exp(-3.629764065335753E-4*T)+0.21760000000000002*exp(-T/271))/(1+(-0.4+log10(1.35E12*T^(-2.57-nf_36)*exp(-5962.2/(R_const*T))*(0.7*c_s1+c_s2+2*c_s3+c_s4+c_s5+c_s6+c_s7+c_s8+c_s9+c_s10+c_s11+c_s12+2*c_s13+c_s14+c_s15+c_s16+c_s17+2*c_s18+3*c_s19+6*c_s20+c_s21+c_s22+c_s23+1.5*c_s24)*exp(Ef_36/(R_const*T))/Af_36)-0.67*log10(exp(-1.5220700152207003E-4*T)+0.7824*exp(-3.629764065335753E-4*T)+0.21760000000000002*exp(-T/271)))^2/(0.75-0.14*(-0.4+log10(1.35E12*T^(-2.57-nf_36)*exp(-5962.2/(R_const*T))*(0.7*c_s1+c_s2+2*c_s3+c_s4+c_s5+c_s6+c_s7+c_s8+c_s9+c_s10+c_s11+c_s12+2*c_s13+c_s14+c_s15+c_s16+c_s17+2*c_s18+3*c_s19+6*c_s20+c_s21+c_s22+c_s23+1.5*c_s24)*exp(Ef_36/(R_const*T))/Af_36)-0.67*log10(exp(-1.5220700152207003E-4*T)+0.7824*exp(-3.629764065335753E-4*T)+0.21760000000000002*exp(-T/271)))-1.27*log10(exp(-1.5220700152207003E-4*T)+0.7824*exp(-3.629764065335753E-4*T)+0.21760000000000002*exp(-T/271)))^2))*exp(Ef_36/(R_const*T))/((1+1.35E12*T^(-2.57-nf_36)*exp(-5962.2/(R_const*T))*(0.7*c_s1+c_s2+2*c_s3+c_s4+c_s5+c_s6+c_s7+c_s8+c_s9+c_s10+c_s11+c_s12+2*c_s13+c_s14+c_s15+c_s16+c_s17+2*c_s18+3*c_s19+6*c_s20+c_s21+c_s22+c_s23+1.5*c_s24)*exp(Ef_36/(R_const*T))/Af_36)*T^2.57) I appreciate if someone could guide of a way to solve this problem. Regardsm, Zari
Posted: 1 decade ago 16.10.2013, 14:14 GMT-4
The post that I wrote a few months ago was for COMSOL 4.2a. I just recently tried to import mechanisms in 4.3b and some errors in the "Import Chemkin files" utility have been corrected compared to the previous version but not all of them as you pointed out. In the end to solve my problem I just corrected manually the wrong reaction rate expressions and verified that a plug-flow calculation with Chemkin gave the same answer as Comsol. My reaction mechanism wasn't too big (only 10 species) so this strategy was manageable.
Hope this was helpful
Good luck!
The post that I wrote a few months ago was for COMSOL 4.2a. I just recently tried to import mechanisms in 4.3b and some errors in the "Import Chemkin files" utility have been corrected compared to the previous version but not all of them as you pointed out. In the end to solve my problem I just corrected manually the wrong reaction rate expressions and verified that a plug-flow calculation with Chemkin gave the same answer as Comsol. My reaction mechanism wasn't too big (only 10 species) so this strategy was manageable. Hope this was helpful Good luck!
Posted: 1 decade ago 18.10.2013, 05:58 GMT-4
Hi Alberto,
Thank you so much for your reply.
I have 24 species and 104 reactions. I think it is risky to change the rate expressions manually. The reaction engineering part be solve alone, but when it comes to combine it with CFD module interfaces (Turbulent flow+ heat transfer+ diluted species transport) then I get an error about log 10 of a negative number that comes from the Troe coefficients at rate expressions.
I hope I could fix the errors soon.
Cheers
Zari
Hi Alberto, Thank you so much for your reply. I have 24 species and 104 reactions. I think it is risky to change the rate expressions manually. The reaction engineering part be solve alone, but when it comes to combine it with CFD module interfaces (Turbulent flow+ heat transfer+ diluted species transport) then I get an error about log 10 of a negative number that comes from the Troe coefficients at rate expressions. I hope I could fix the errors soon. Cheers Zari
Posted: 1 decade ago 18.10.2013, 14:08 GMT-4
I rember having a similar problem, it had something to do with how I set up intial conditions, but I don't remeber exactly, let me know if you don't manage to solve the problem, I can take a better look to what I did. Have you already contacted the Comsol support about this problem? If you haven't, can you do me a favor and contact them? If they see that many people have the same problem hopefully they will eventually correct the software errors (these errors have been around for a few years and it is annoying) Thanks and good luck.
Posted: 1 decade ago 21.10.2013, 08:02 GMT-4
Hi Alberto,
I appreciate if you could again look at your model and tell me how you managed the problem. My Chemkin kinetic s includes 104 reactions (most of them reversible) and 24 species (most of them are radicals and dissociation species ). I thought that if I remove the Troe coefficients from the Chemkin file then I will have the rates according to the Lindemann which does not have a Log 10 and will be a simpler way.
The kinetic was again being solved with this but I still have errors solving CFD, at mass transport level. which points to reaction rate.
I have contacted Comsol support from 2-3 months ago and it\s still an active case :(
May I have your email and send you my model maybe you could have a look at that, if.if.if you have time?
Zari
Hi Alberto, I appreciate if you could again look at your model and tell me how you managed the problem. My Chemkin kinetic s includes 104 reactions (most of them reversible) and 24 species (most of them are radicals and dissociation species ). I thought that if I remove the Troe coefficients from the Chemkin file then I will have the rates according to the Lindemann which does not have a Log 10 and will be a simpler way. The kinetic was again being solved with this but I still have errors solving CFD, at mass transport level. which points to reaction rate. I have contacted Comsol support from 2-3 months ago and it\s still an active case :( May I have your email and send you my model maybe you could have a look at that, if.if.if you have time? Best, Zari
Posted: 1 decade ago 14.04.2015, 11:09 GMT-4
Hi everyone,
is there someone with experience of importing chemkin files in comsol 5.0 and with chemical reactions in comsol in general? I'm having a hard time with this and wanted to ask, if someone has an answer. What I wonder is, how three body reactions are calculated in comsol.
What I did was this: I imported the grimech30.dat reaction mechanism and seperated the first three body reaction: 2O + M <=> O2 + M. Now comsol recognizes the species, O, O2 and M. The first two species are clear, but why is "M" considered a species? "M" is just a collision partner and should not be specified. But comsol wants thermodynamic data for it.
Thanks in advance
Göksel Özuylasi
Hi everyone, is there someone with experience of importing chemkin files in comsol 5.0 and with chemical reactions in comsol in general? I'm having a hard time with this and wanted to ask, if someone has an answer. What I wonder is, how three body reactions are calculated in comsol. What I did was this: I imported the grimech30.dat reaction mechanism and seperated the first three body reaction: 2O + M O2 + M. Now comsol recognizes the species, O, O2 and M. The first two species are clear, but why is "M" considered a species? "M" is just a collision partner and should not be specified. But comsol wants thermodynamic data for it. Thanks in advance Göksel Özuylasi
