28.12.2009, 05:13 GMT-5
Hi Andy,
to be honest I really do not understand why you need to generate a random initial condition. If you can, more details would be very much appreciated. By the way, I guess that you can solve your problem by running Comsol with Matlab (whereas you have a valid licence). In this way, just type "rand(1,1)" in the related field of the "init" tab.
Moreover, if you need to generate a set of random values, run a parametric analysis, in which every parameter is a random value. Maybe that the best way to run such as analysis is into matlab environment. Save your job as .m file and then open it into matlab editor. Here, you are able to define your functions as input for your simulation.
Hope this is helpful,
Pasquale
Hi Andy,
Pasquale
28.12.2009, 05:23 GMT-5
If its a random time series, you can perhaps express it as a PSD and use that as an envelope for a harmonic analysis, this is often used for random vibration analysis fo structures
