Plotting Current
I have a system consisting of 2 electrodes in a box. I selected the medium in the box (on top of the electrodes) as Water. Now I want to plot the electric filed and the current between and above the electrodes.
The electric field can be plot by Cross-section plot, but there is no option about plotting the current.
Is there any special methods for plotting current in any system in Comsol?
I'm working with 3.5a Version
6 Replies Last Post 18.05.2017, 20:50 MESZ
Posted: 1 decade ago 27.07.2011, 08:43 MESZ
Hi there,
To plot current, you got to set up a subdomain integration variable which integrate the current density over all simulated domains.
To do so, you may go to Options\Integration Coupling Variables\Subdomain Variables. Remember to find out the built-in expression for current density.
All the best,
David
[QUOTE] I have a system consisting of 2 electrodes in a box. I selected the medium in the box (on top of the electrodes) as Water. Now I want to plot the electric filed and the current between and above the electrodes. The electric field can be plot by Cross-section plot, but there is no option about plotting the current. Is there any special methods for plotting current in any system in Comsol? I'm working with 3.5a Version [/QUOTE] Hi there, To plot current, you got to set up a subdomain integration variable which integrate the current density over all simulated domains. To do so, you may go to Options\Integration Coupling Variables\Subdomain Variables. Remember to find out the built-in expression for current density. All the best, David
Posted: 1 decade ago 27.07.2011, 18:34 MESZ
Dear David
Thanks a lot for your reply.
I can not understand this part of your answer:
"Remember to find out the built-in expression for current density."
should I define some special expression for Current density by myself? I mean by special formula or number?
Dear David Thanks a lot for your reply. I can not understand this part of your answer: "Remember to find out the built-in expression for current density." should I define some special expression for Current density by myself? I mean by special formula or number?
Posted: 1 decade ago 27.07.2011, 18:42 MESZ
In order to describe the problem more accurately , I can say I am re-simulating one of the Comsol examples "Capacitive 3D comb drive" which is available on line.
Now, in this system, I want to plot the current
In order to describe the problem more accurately , I can say I am re-simulating one of the Comsol examples "Capacitive 3D comb drive" which is available on line. Now, in this system, I want to plot the current
Posted: 1 decade ago 28.07.2011, 04:47 MESZ
Hi there,
The expression for current density is already generated as an build-in parameter which you can refer to the user's guide to find out the exact form. It could be like normJ_emdc. Try to read user's guide or Google it.
All the best,
David
Hi there, The expression for current density is already generated as an build-in parameter which you can refer to the user's guide to find out the exact form. It could be like normJ_emdc. Try to read user's guide or Google it. All the best, David
Posted: 1 decade ago 28.07.2011, 17:01 MESZ
Dear David. Thanks a lot for your great help
I also find another way to solve this problem but I am not sure if it's correct or not. I would appreciate if you could comment on this.
Before this, I simulated the system I explained in MEMS MODULE--->ELECTROSTATICS
then yesterday, I change this and simulate the system in ELECTROMAGNETIC--->CONDUCTIVE MEDIA DC
now in this mode, I can plot the current density directly in the program.
I have saw systems similar to mine which were simulated in both of these modes so I am not sure which one is correct.
Moreover, when I do the integration it will only give me a number as a final result. I can not draw a plot with this integration technique, Is that right? or may be I am missing something.
I appreciate your kind help and Reply David
Dear David. Thanks a lot for your great help I also find another way to solve this problem but I am not sure if it's correct or not. I would appreciate if you could comment on this. Before this, I simulated the system I explained in MEMS MODULE--->ELECTROSTATICS then yesterday, I change this and simulate the system in ELECTROMAGNETIC--->CONDUCTIVE MEDIA DC now in this mode, I can plot the current density directly in the program. I have saw systems similar to mine which were simulated in both of these modes so I am not sure which one is correct. Moreover, when I do the integration it will only give me a number as a final result. I can not draw a plot with this integration technique, Is that right? or may be I am missing something. I appreciate your kind help and Reply David
Posted: 8 years ago 18.05.2017, 20:50 MESZ
Updated: 8 years ago 18.05.2017, 20:50 MESZ
Hi david
I am using 5.2a. Where exactly is the option for Options\Integration Coupling Variables\Subdomain Variables located in comsol.
Hi david I am using 5.2a. Where exactly is the option for Options\Integration Coupling Variables\Subdomain Variables located in comsol.
