Parametric sweep
Posted 22.07.2011, 04:25 GMT-4 Parameters, Variables, & Functions, Studies & Solvers Version 4.2 1 Reply
I defined a parameter at global definitions (Name: para; Expression: 1).
My inflow heat flux depends on the daytime and the emission coefficient - so i defined the Inflow heat flux as a sine function of time multiplied by "para".
I added at "Parametric sweep" the parameter "para" and defined the range to be take into consideration as (range(0.1,0.1,1).
By trying to solve i get the Error: "Error in sweep: Parameter names must not be empty".
But: The parameter names are not empty. What have I done wrong?
NR
NR
1 Reply Last Post 27.07.2011, 03:02 GMT-4
