Export boundary topography and relative simulated stresses
Dear all,
Recently, I have been struggling with something that I guess should be pretty straightforward.
I have a simple cubic component with one randomly rough face - so one boundary is a rough surface. To this component, I have applied a predescribed strain and some stresses generated. I would need to export a 4 columns file (.txt or any other file is ok) in which 3 of them are the x y and z coordinates of each point - they basically give me the surface topography - and the last column report the actual Von mises stress at each point.
Is there anybody out there who has a quick idea of how to do that? Thanks a lot.
Best, Marco
1 Reply Last Post 16.08.2018, 02:36 GMT-4
Posted: 7 years ago 16.08.2018, 02:36 GMT-4
Updated: 7 years ago 16.08.2018, 02:37 GMT-4
I suggest that you try the following:
  • Results > Export: Add a Data export feature.
  • Choose the data set that you are interested in.
  • Add the expression for the von Mises stress to the Expression table. It's typically solid.mises for a structural mechanics model.
  • Change Geometry level to Surface.
  • Set the Filename.
  • Click on Export.
If you're only interested in the stresses on one single face, you can add a selection to the data set.
I suggest that you try the following: - Results > Export: Add a Data export feature. - Choose the data set that you are interested in. - Add the expression for the von Mises stress to the Expression table. It's typically solid.mises for a structural mechanics model. - Change Geometry level to Surface. - Set the Filename. - Click on Export. If you're only interested in the stresses on one single face, you can add a selection to the data set.
