Hello Simon True
2 decades ago
20.01.2010, 04:41 GMT-5
Hello Simon,
actually I am also building a model of a glass mirror. I want to investigate the thermal influence to the surface deformation of the mirror and I also need to export the deformation in the end.
Did you already succeed in exporting the data? Under File->Export->Postprocessing Data I can Export Coordinates, but I don´t know how to export the coordinates of exactly the surface or subdomain I am interested in!
Moritz
Hello Simon,
Moritz
2 decades ago
20.01.2010, 22:11 GMT-5
You can export the deformations into matlab, one way is to take a look on the discussion thread "" this is for eigenmodes but the deformations ramin deformations:)
Matlab script for effective modal mass extraction
You have also some clues in the "Model Exchange" (and a few discussions threads, serach for Zernike) where I have dumped a very preliminary Zernike analysis of a deformed surface, that I use for mirror gravity and thermal deformation analysis. It is rather straightforward, but length to extend to further zernike elements. Pls note that there is a normalisation issue to consider depending on which optical software you are comparing your results with. And that the Zernike are correctly normalised only for circular, non hollow, shapes.
There are quite some info in the threads, try the "search" it can extract several nice suggestions
