Temperatures higher than adiabatic flame temp
Hydrogen Peroxide decomposition in a micro channel
I am trying to model a subsection of an array of pillars coated in a catalytic material. Everything seems very reasonable except i am getting temperatures greater than the analytical max of about 1250K.
I am skeptical of two things:
First the difference between batch flow and plug flow as an reaction type
Second the way in which i am adding heat .
One final question is when the reaction engineering is not checked in the second study?
6 Replies Last Post 20.06.2011, 12:26 GMT-4
Posted: 1 decade ago 19.06.2011, 22:49 GMT-4
Your case seems simple. I think you should try solving your problem without using reaction engineering physics..just use flow, heat and diluted species physics..
Mayur
Hi, Your case seems simple. I think you should try solving your problem without using reaction engineering physics..just use flow, heat and diluted species physics.. Mayur
Posted: 1 decade ago 20.06.2011, 08:49 GMT-4
Removing reaction engineering seems like it will remove one level of communication, but it also removes my ability to add Chemkin data. How do i define the material properties of the gas without that?
Posted: 1 decade ago 20.06.2011, 09:45 GMT-4
First just define all the properties under parameters if they are constant or under variables if they are varying. I would suggest, first define all the properties as constant values and run your simulation.
Posted: 1 decade ago 20.06.2011, 09:49 GMT-4
Posted: 1 decade ago 20.06.2011, 12:01 GMT-4
Thanks that makes sense, then do i need to great new materials or just use air?
Posted: 1 decade ago 20.06.2011, 12:26 GMT-4
comsol doesn't understand material..it understands only numerical values..you can get all required values from any chemical engineering handbook related to the species in your reactions..
