residual stresses of thermal spray coating process
I'm trying to simulate a thermal spray coating process, with COMSOL Multyphycis v4.0a.
My model is a multiple-layer Fe3Al / Al2O3 gradient coating on carbon steel substrate. I use a 2D axisymmetric geometry.
3 steps are needed to simulate the deposition of each layer :
- pre-heating of the substrate (or pre-deposited layer) (h=300 W/m².K and T=3000K)
- deposition of the coating layer
- cooling-down
The coating is composed of 5 layers.
I use 6 physics "Heat Transfer" for the thermal analysis. I would like to know how to use the final temperature of layer N as initial temperature of layer N + 1 .
Thanks for your help!
Alexis
3 Replies Last Post 11.09.2014, 09:03 GMT-4
Posted: 1 decade ago 17.06.2011, 00:20 GMT-4
I'm not sure to have been clear.
I want to use final temperature of "Heat Transfer" N as initial temperature of "Heat Transfer" N+1.
Alexis
I'm not sure to have been clear. I want to use final temperature of "Heat Transfer" N as initial temperature of "Heat Transfer" N+1. Regards, Alexis
Posted: 1 decade ago 20.06.2011, 01:43 GMT-4
I have found a way to solve my problem.
The 10 steps of my process (pre-heating1, layer1,......, pre-heating5, layer 5) are solved by a different solver.
Each solver has as initial values the solution of the solver before. I have updated the geometry as one goes along.
It's working, but I would like to know if there are more simple ways to solve my model.
Alexis
I have found a way to solve my problem. The 10 steps of my process (pre-heating1, layer1,......, pre-heating5, layer 5) are solved by a different solver. Each solver has as initial values the solution of the solver before. I have updated the geometry as one goes along. It's working, but I would like to know if there are more simple ways to solve my model. Regards, Alexis
Posted: 1 decade ago 11.09.2014, 09:03 GMT-4
Now I am doing exactly the same same work as you have done by COMSOL, I would like to konw if you have found the better and easy way to solve this multilayered coating by using 'birth and death unit' in COMSOL?
Thank you
Hi, Now I am doing exactly the same same work as you have done by COMSOL, I would like to konw if you have found the better and easy way to solve this multilayered coating by using 'birth and death unit' in COMSOL? Thank you
