Help...the model elevator button in Version4.1...how to define the piezoresistivity
There are errors when opening the elevator button in version v4.1...as following when defining the variable:
Name:sxl expression: sxl_smsld description: Material stress in local coordinates
Name: rho11 expression: coord1_T11*(rhol11*coord1_T11+rhol12*coord1_T12+rhol13*coord1_T13)+coord1_T12*(rhol12*coord1_T11+rhol22*coord1_T12+rhol23*coord1_T13)+coord1_T13*(rhol13*coord1_T11+rhol23*coord1_T12+rhol33*coord1_T13)
description: Relative resistivity (rho/rho0) in global coordinates
Please help me........
3 Replies Last Post 25.05.2011, 10:47 GMT-4
Posted: 1 decade ago 25.05.2011, 09:43 GMT-4
From the naming convention you have opened a 3.5 model I believe. I have given up reusing older version in v4.1, I find it much quicker to rebuild them in V4 from scratch (you open at most the old model side by side to copy complex formulas if you have some, or the geometry
This has shown for me to solve most of these issues, I find it finally quicker and I learned faster the new v4 way like that. But you might have a different opinion ;), Unfortunately I cannot propose anything better
Hi From the naming convention you have opened a 3.5 model I believe. I have given up reusing older version in v4.1, I find it much quicker to rebuild them in V4 from scratch (you open at most the old model side by side to copy complex formulas if you have some, or the geometry This has shown for me to solve most of these issues, I find it finally quicker and I learned faster the new v4 way like that. But you might have a different opinion ;), Unfortunately I cannot propose anything better -- Good luck Ivar
Posted: 1 decade ago 25.05.2011, 10:00 GMT-4
Thanks Ivar... I am a beginner. I spent lots of time googling on how to set up the piezoresistive silicon in v4.1...but found nothing....anyone knows?? please help.....
[QUOTE] Hi From the naming convention you have opened a 3.5 model I believe. I have given up reusing older version in v4.1, I find it much quicker to rebuild them in V4 from scratch (you open at most the old model side by side to copy complex formulas if you have some, or the geometry This has shown for me to solve most of these issues, I find it finally quicker and I learned faster the new v4 way like that. But you might have a different opinion ;), Unfortunately I cannot propose anything better -- Good luck Ivar [/QUOTE] Thanks Ivar... I am a beginner. I spent lots of time googling on how to set up the piezoresistive silicon in v4.1...but found nothing....anyone knows?? please help.....
Posted: 1 decade ago 25.05.2011, 10:47 GMT-4
unfortunately no for me, to be sure I made myself understood, use the 3.5 translation to inspire yourself to rebuild the model, at least that way you end up with coherent BCs and variable names in V4.
Do not forget to update your model library in V4, there are regularly new goodies coming in that way ;)
Hi unfortunately no for me, to be sure I made myself understood, use the 3.5 translation to inspire yourself to rebuild the model, at least that way you end up with coherent BCs and variable names in V4. Do not forget to update your model library in V4, there are regularly new goodies coming in that way ;) -- Good luck Ivar
