how can i set over hundreds different boundary conditions automaticly?
hi, i have a geometry consists of over hundreds rectangular and each has different boundary condition value on one side, can not figure out how to set it in comsol ?
Any one knows?
2 Replies Last Post 01.12.2009, 16:50 GMT-5
Posted: 2 decades ago 25.11.2009, 15:22 GMT-5
Matlab again will probably be the only efficient way. You'll see from Comsol m-files that the boundary conditions and subdomain properties are formatted in matrix form (using brackets). Thus, you should be able to define a matrix that contains all of the boundary conditions (i.e. a vector containing the force applied at each boundary), then use that matrix when writing the m-file. I can't give you much more explanation than that as I don't know the nature of the B.C.s that you are setting.
Good luck,
Mike
Matlab again will probably be the only efficient way. You'll see from Comsol m-files that the boundary conditions and subdomain properties are formatted in matrix form (using brackets). Thus, you should be able to define a matrix that contains all of the boundary conditions (i.e. a vector containing the force applied at each boundary), then use that matrix when writing the m-file. I can't give you much more explanation than that as I don't know the nature of the B.C.s that you are setting. Good luck, Mike
Posted: 2 decades ago 01.12.2009, 16:50 GMT-5
yeah, thanks Mike, i would try to solve it in matlab
