23.05.2011, 08:57 GMT-4
I do not follow you when you say that the 2D-axi and the standard 2D differs, for me this is normal, as 2D has an "infinite" or "per meter " depth along Z, while the 2D axis has a loop length worth 2*pi*r. This is a radically different topology , hence different mode shapes
normally the 2D-axi takes care of the r=0 (by multiplying many of the formulas by "r" and then normalising back the results. But one should not forget that a 2D-axi symmetry means really that the axis remains fixed and that all phenomena are radially symmetric
23.05.2011, 09:58 GMT-4
Dear Ivar,
Apologies for not phrasing the problem clearly and thanks for your fast reply! In the regular 2d case I study a circle that should have the same dimensions as the the port that I defined as a line from r=0 in the 2D axisymmetric case (if I unstand the 2D axisymmetry correcly).
Do I not correctly assume that applying a mode analysis to the regular 2D circle should yield the same effective mode index as the a boundary mode analysis to this 'line' from r=0 in the 2D axisymmetric case?
Boris
Dear Ivar,
Boris
23.05.2011, 10:19 GMT-4
For clarity, these are the geometries I use (in the 2D axisymmetric case my port is at z=0)
28.02.2012, 06:31 GMT-5
Shouldn't the 'dif' half circles on the top of your 2D-axi actually be rectangle-shaped? Because this revolves around the r=0 axis and the circular fiber profile would be created automatically...
Clenilson Rodrigues da Silveira
19.07.2012, 15:09 GMT-4
Hi! I'm a new user of Comsol. I got an evaluation trial license. I need to model a tapered fiber. So firstly, I decided to run simple examples contained in model library. I ran RF/step_index_fiber. I tried to follow the same steps contained in this example but in 2D axisymmetric and 3D model. But unfortunately I did not get the same results. In 3D model I couldn't get any distribution of electrical field. I realized that it is a common problem but anyone was able to appropriately answer those kind of questions. Is it a problem related to excitation? Thanks in advance.
12.01.2014, 12:04 GMT-5
I've come across exactly the same question just as you did. I want to simulate a model that a continuous wave pass through a fiber taper with different diameters at the two ends. Firstly, I want to simulate a Single Mode Fiber as a test, but it doesn't work either. Have you solve it yet?
