Rotation, Rheological model
I am trying to simulate fluid flow in a pipe but I have two problems. I appreciate if anybody give me some hint:
1. I just see three rheological models available in COMSOL: Newtonian, Carreau, and Power law. So how is it possible to simulate another rheological models such as Herschel_ Bulkley, etc?
2. I dont see an option in COMSOL( although it is in the help) to simulation rotation of a pipe. In the options for wall boundary conditions, there is no such capability.
1 Reply Last Post 25.05.2011, 08:02 GMT-4
Posted: 1 decade ago 25.05.2011, 08:02 GMT-4
Herschel_ Bulkley is a rheological model with a yield stress. Below the yield stress the material behaves like a solid and above the yield stress the material behaves like a fluid. So you have a stress dependent phase transsition and the solid state (the relation between stress and strain) is not defined in Herschel_ Bulkley.
I guess, you have to build a workaround.
For modeling of rotating walls see the tutorial "dense suspension".
greetings
Uwe
Hi, Herschel_ Bulkley is a rheological model with a yield stress. Below the yield stress the material behaves like a solid and above the yield stress the material behaves like a fluid. So you have a stress dependent phase transsition and the solid state (the relation between stress and strain) is not defined in Herschel_ Bulkley. I guess, you have to build a workaround. For modeling of rotating walls see the tutorial "dense suspension". greetings Uwe
