Confusing Error Message
Hi All,
I've been working for a bit on a model of a detector using the mf interface from the AC/DC module, but have realized that I muight reformulate the problem using the mef interface (mf doesn't connect to a circuit how I want). I've set up the model the same way for the mef version as I did for mf, and am trying to run it in both stationary and frequency domain studies. However, I get the following error message:
  • Feature: Stationary Solver 1 (sol2/s1) Failed to find a solution. The relative residual (1.1e+011) is greater than the relative tolerance. There was a warning message from the linear solver. Iterative refinement triggered. Returned solution is not converged.
I've attached the model below and was hoping someone could explain how to fix this. It's a pretty simple problem that can be done with pencil and paper, so I suspect that I'm missing some simple technical detail about COMSOL that I haven't found in my online searches so far.
Thanks, Henry
2 Replies Last Post 20.09.2018, 17:08 GMT-4
Posted: 7 years ago 17.07.2018, 17:03 GMT-4
Hi Henry,
Have you tried with a finer mesh? Plus, try change the error tolerance and the solver and see if it helps
Regards, Nichal
Hi Henry, Have you tried with a finer mesh? Plus, try change the error tolerance and the solver and see if it helps Regards, Nichal
Posted: 6 years ago 20.09.2018, 17:08 GMT-4
Henry,
the air domain needs a higher conductivity, 1 S/m works. I also changed the direct solver to PARDISO, which frequently converges better.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Henry, the air domain needs a higher conductivity, 1 S/m works. I also changed the direct solver to PARDISO, which frequently converges better. Cheers Edgar
