Integration formula
I am modelling a heat exchanger problem. I have good validation with experimental data. How can I get the value of the integration for any variable (such as the temperature) along any line rather than the edges of the domain?
3 Replies Last Post 11.05.2011, 10:21 GMT-4
Posted: 1 decade ago 10.05.2011, 13:29 GMT-4
you have also the "cut line option" in 3.5, it is in one of the options of the postprocessing tab, unfortunately I do no longer have a running version, check the doc
Hi you have also the "cut line option" in 3.5, it is in one of the options of the postprocessing tab, unfortunately I do no longer have a running version, check the doc -- Good luck Ivar
Posted: 1 decade ago 11.05.2011, 10:19 GMT-4
What about the other versions.
Thanks What about the other versions.
Posted: 1 decade ago 11.05.2011, 10:21 GMT-4
many more in V4, check the right click on the data set node, AND check your doc ;)
Hi many more in V4, check the right click on the data set node, AND check your doc ;) -- Good luck Ivar
