Open File in comsol version 5.3
Hi everyone, I'd like open the "Switched Reluctance Motor" example, but it is in version 5.3a. How can I open in version 5.3?
Regards, Rute
2 Replies Last Post 17.06.2018, 12:14 GMT-4
Posted: 7 years ago 15.06.2018, 01:34 GMT-4
Updated: 7 years ago 15.06.2018, 01:34 GMT-4
Hi Rute,
You can not open a file from a newer version in an older version. It only works the other way around. Newer version of the program contains functionality which is not present in the older version.
Most models are availble in several versions on https://www.comsol.com/models , but that depends on in which version it was originally introduced.
Henrik
Henrik Sönnerlind
COMSOL
Hi Rute, You can not open a file from a newer version in an older version. It only works the other way around. Newer version of the program contains functionality which is not present in the older version. Most models are availble in several versions on , but that depends on in which version it was originally introduced. Regards, Henrik
Posted: 7 years ago 17.06.2018, 12:14 GMT-4
Thanks for reply I got it.
Regards, Rute
Thanks for reply I got it. Regards, Rute
