Leak simulation in a double pipe heat exchanger
Posted 07.06.2018, 09:22 GMT-4 Fluid & Heat, Computational Fluid Dynamics (CFD) Version 5.2a 1 Reply
Dear all,
I am simulating a double pipe heat-exchanger.
A double pipe heat-exchanger is a simple assembly with a pipe inside another big pipe. The fluid in inner pipe is A and another fluid B passes through the annular section of the asembly.
I want to simulate a condition in which the inner pipe has some holes / cracks on its surface.
But the issue is, the moment I create the hole, the fluid domain combines and only one fluid remains.
Can I simulate a scene in which, a fluid is leaking into another??
Please help me in this case.
thank you.
