06.05.2011, 09:16 GMT-4
I do not see why it does not work so long radius is different from "0". Perhaps you could use atan2(y,x) instead of the asin() (OK so long x is different from "0").
Again it depends where you apply your variable/equation as if you define it on an edge or surface passing by x=y=radius=0 you might have an issue
06.05.2011, 09:24 GMT-4
Thanks for the reply. But no I do not define the variable anywhere close the origin. Actually, the circle is centered in (0,0) so that guarantees no singularity.
I am afraid what you said just confirmed my suspicions: it does seem to be a bug.
Please look at the picture I attached and you will see what I mean by funny behaviour!
Thanks again for the reply.
Cheers
Cheers
Jeff Hiller
COMSOL Employee
06.05.2011, 10:51 GMT-4
Asin returns a value between -pi/2 and +pi/2, so the cos of that is always positive. What's so surprising?
06.05.2011, 11:11 GMT-4
Thanks! So that was the rub! Well, I would say that is surprising that you don't get that mentioned in the definition of asin in the Comsol Local help, where they state:
asin inverse sine asin(x)
under 'Mathematical functions'
So a little more explaining would be in order for the next edition of the Local help, because it is definitely counter-intuitive to have to imagine that you asin is limited between -pi and +pi...
One more question then, what are the boundaries for atan? (Again it is not explicitly stated) 0 and pi? -pi and 0?
Jeff Hiller
COMSOL Employee
06.05.2011, 11:27 GMT-4
That's the usual definition of arcsin, see for instance Wikipedia:
en.wikipedia.org/wiki/Inverse_trigonometric_functions
That's the usual definition of arcsin, see for instance Wikipedia: http://en.wikipedia.org/wiki/Inverse_trigonometric_functions
06.05.2011, 11:31 GMT-4
Awesome, but we purchased Comsol and not Wikipedia.
I am curious why standard? I am sorry but as a mathematician-engineer such a definition does not make much sense, whenever I solve for an ODE or a PDE I don't think an inverse trigonometric function is usually defined between two angles.
At any rate atan is then limtied between -pi/2 and pi/2?
06.05.2011, 14:52 GMT-4
the easiest is to test it out with the analytical function functionality (and plot otion) og V4.
test also atan2(,) I believe its defined for a "full turn"
again this is ususal math definitions. In the function definitions you have ways to make them periodic again
