Exporting data on mesh nodes
Posted 26.05.2018, 16:39 GMT-4 Mesh, Results & Visualization Version 5.3a 2 Replies
Hi, I need to export mechanical vibration eigenfrequency data which could lie exactly on the mesh nodes coordinates. Although I am able to export quite similar coordinates, there is always a mismatch between exported mesh node coordinates in .stl file and node coordinates for exported data from dataset. This occurs at far decimals, but as I am importing data into matlab from csv files I am no more able to easily associate data to mesh nodes for plotting. I tried to switch to Mesh frame but it seems to be useless. I also tried to export xmesh data from livelink for matlab and try to build my own mesh with nodes realigned with the data through an stlwrite matlab routine but I am not able to obtain a working mesh. I ran out of ideas. Is there a way to simply obtain data on mesh nodes? Thank you!
