Disk space reached while matrix assembly
I have a huge simulation with a big mesh and during the calculation the programm crashes when the virtual memory reaches ca. 27 gb. The error said that disk space exceeded while matrix assembly. But normally my system does not limit the virtual memory. I am running Comsol 4.1.0.185 under Windows 7 with 12 gb ram and 500 gb free disk space.
I would be thankful for an immediate answer.
Kind regards
Daniel
4 Replies Last Post 06.05.2011, 15:06 MESZ
Posted: 1 decade ago 05.05.2011, 15:48 MESZ
have you checked the swap space? , you might be limited to 1-2 times your total ram,
This is an OS setting, you can increase it in the Control panel settings somewhere ;)
Hi have you checked the swap space? , you might be limited to 1-2 times your total ram, This is an OS setting, you can increase it in the Control panel settings somewhere ;) -- Good luck Ivar
Posted: 1 decade ago 05.05.2011, 15:56 MESZ
Thanks for your answer, but I already done that. I change the virtual memory from system controlled to max. 100 gb but the problem is still the same.
Posted: 1 decade ago 05.05.2011, 18:04 MESZ
Could my problem with the virtual memory be a Windows 7 bug? I personally prefer Linux, but I have to use Windows 7 64 bit at work.
I try to upload the simulation file here but it is 144 mb large:
dl.dropbox.com/u/9291271/versuch.mph
Maybe this would help somebody to understand my problem.
Could my problem with the virtual memory be a Windows 7 bug? I personally prefer Linux, but I have to use Windows 7 64 bit at work. I try to upload the simulation file here but it is 144 mb large: http://dl.dropbox.com/u/9291271/versuch.mph Maybe this would help somebody to understand my problem.
Posted: 1 decade ago 06.05.2011, 15:06 MESZ
It's me again. :)
I think I solved my problem. I changed the assembly block size to 1000 under the advanced stationary solver. Now Comsol computes a result for my simulation. But could anybody explain to me what I've really done? I just desperate changed some values which make no sense to me and had luck with the choice of assembly block size 1000.
It's me again. :) I think I solved my problem. I changed the assembly block size to 1000 under the advanced stationary solver. Now Comsol computes a result for my simulation. But could anybody explain to me what I've really done? I just desperate changed some values which make no sense to me and had luck with the choice of assembly block size 1000.
