Deviations from calculations-simulation-tests
How exactly match the calculated values with simulated as well as determined by tests? I am particularly interested in values of magnetism, respectively magnetic fields of permanent magnets.
1 Reply Last Post 05.05.2011, 14:56 MESZ
Posted: 1 decade ago 05.05.2011, 14:56 MESZ
I would sa there is no defintive answer.
You can get within a few percent (then mostly I'm happy), if you leave your supercomputer run longer within a few ppm.
But this applies only to the equivalence of your model to the results of this simplfied model.
If you are ignoring a full physicsal branch taking place for your measured values, then you may be >100% off too ;)
Hi I would sa there is no defintive answer. You can get within a few percent (then mostly I'm happy), if you leave your supercomputer run longer within a few ppm. But this applies only to the equivalence of your model to the results of this simplfied model. If you are ignoring a full physicsal branch taking place for your measured values, then you may be >100% off too ;) -- Good luck Ivar
