Expression dialog box problem
Hello COMSOL community,
Recently, my COMSOL Desktop 5.3a has some problems with the input into the expression dialog box. When I type some contents, e.g. a number into the Parameters->Expression, the contents will disappear if I click the mouse on the other box or use the Tab key on the keyboard to move to the other box. I have to use the Enter key to keep the content, which has been annoying me a lot recently.
I uninstalled the COMSOL Desktop and reinstalled it several times, but the problem is still there. I even tried 5.3 vernon, but still encountered the same problem. I am not sure it's because of the window system or COMSOL. However, in other sofewares, there are no the problems.
Did anyone meet the same problem before? any solution?
Thanks.
3 Replies Last Post 23.07.2018, 21:03 GMT-4
Hello Dragon Li
Posted: 7 years ago 23.07.2018, 10:09 GMT-4
I have the same problem.
Were you able to fix it?
I have the same problem. Were you able to fix it?
Posted: 7 years ago 23.07.2018, 10:24 GMT-4
take a look at this:
https://www.comsol.com/support/knowledgebase/1248/
Kind regards, Shaghayegh
Hi, take a look at this: https://www.comsol.com/support/knowledgebase/1248/ Kind regards, Shaghayegh
Posted: 7 years ago 23.07.2018, 21:03 GMT-4
Hi Ali,
Shaghayegh provided the ture answer to solve this issue. I just found it several days ago.
Hi Ali, Shaghayegh provided the ture answer to solve this issue. I just found it several days ago.
