03.05.2011, 08:59 GMT-4
I'd also like to hear any suggestions as I'm modelling something similar. I can get it to work with a velocity profile inlet and fixed pressure outlet, but when I try to change the boundary conditions, the solver fails to find a solution.
03.05.2011, 16:40 GMT-4
if you are in turbulent mode, it could come from a to coarse mesh, I just had one of those surprises ;)
03.05.2011, 22:00 GMT-4
Ivar,
I've actually thought about the problem of entering a turbulent flow regime so I've attempted to run the simulation with Boundary Conditions that provide a small head difference between outlet and inlet.
I have also run the simulation with a finer mesh and it still does not find a solution.
Any other suggestions?
Juan
Ivar,
Juan
04.05.2011, 02:06 GMT-4
It may be due to the fact you have pressure condition both at the inlet and at the outlet but without looking at the model itself I can't guarantee this is the answer.
What is the Reynolds number of your model?
Cheers
Cheers
13.07.2011, 09:38 GMT-4
I have been in the same problem. I think chances are the problem is that the Reynold's number becomes too high. you can try to lower the velocity
