Selecting specific multiphysics
Dear all,
For a simulation I have a 2D axis symmetric tube in a tube problem. In the inner tube flows (domain 1) a fluid with an inlet temperature of -5 °C. The outer tube (domain 2) contains water which is standing still (the initial temperature is 15°C). This water will slowly be frozen to ice.
For the physics I have selected a non-isothermal flow. However the water in domain 2 is not moving. Is it possible to select a non-isothermal flow only for domain 1 and let domain 2 be calculated by a heat transfer in fluids physics?
I'm asking this, because, later on, the simulation will become more complex. It would save a large amount of computational time when in domain 2 only the temperature is calculated (instead of saying many times, velocity=0).
Thank you in advance
1 Reply Last Post 04.04.2018, 08:39 GMT-4
Yara Soares COMSOL Employee
Posted: 7 years ago 04.04.2018, 08:39 GMT-4
Updated: 7 years ago 04.04.2018, 08:57 GMT-4
Dear Erik,
For a swift response, I would like to advise you to submit your question to support@comsol.com.
Met vriendelijke groet, Best regards,
Yara Soares
COMSOL BV | Röntgenlaan 37 | 2719 DX Zoetermeer Phone: +31 (0)79 363 4230 | Fax: +31 (0)79 361 4212
www.comsol.nl | yara.soares@comsol.com
Dear Erik, For a swift response, I would like to advise you to submit your question to support@comsol.com. Met vriendelijke groet, Best regards, Yara Soares -------------------------------------------------------------------------- COMSOL BV | Röntgenlaan 37 | 2719 DX Zoetermeer Phone: +31 (0)79 363 4230 | Fax: +31 (0)79 361 4212 www.comsol.nl | yara.soares@comsol.com -----------------------------------------------
