Airlift Pump simulation,multiphase
Posted 20.04.2011, 09:49 GMT-4 0 Replies
I tried to simulate the airlift pump in the COMSOL 4.0. the boundary an initial conditions are well defined. Once I used pressure boundary for entrance of air and water and outlet and once I used pressure boundary for water and outlet and velocity boundary for air. I also tried 2D, 2D axisymmetric and 3D model (stationary and time dependent). For all cases the software failed to solve the problem. it returns the error that "Failed to find a solution: No convergence, even when using the minimum damping factor. Returned solution has not converged." or the error that says: "Failed to find consistent initial values. Last time step is not converged."
has anyone works on the topic of airlift or multiphase flow?Can anyone help me please?
Thank you
Hello Mehdi Hosseini
