coupling fluid flow with acoustics
Hi, everyone
I would like to know what velocities of a fluid are produced by the vibration of a probe submerged in it. I have already done transient acoustic modeling, where the pressure distributions are found within the fluid. One of the probe boundaries was defined as normal acceleration. However, I am interested in the velocity fields of the fluid. Is it possible to take the pressure as an input for the fluid flow? How can I achieve this? Any ideas?
Thank you
Sylvana
3 Replies Last Post 11.05.2015, 14:35 GMT-4
Hello Sylvana Garcia
Posted: 1 decade ago 31.10.2011, 12:05 GMT-4
Hi Sylvana,
I am trying to model a similar system and have used the transient acoustic modelling in the liquid. Did you manage to couple this to a fluid flow?
Richard
Hi Sylvana, I am trying to model a similar system and have used the transient acoustic modelling in the liquid. Did you manage to couple this to a fluid flow? Thanks, Richard
Posted: 1 decade ago 13.11.2011, 22:55 GMT-5
Hi, Richard
I have left this problem on standby for now, but plan on continuing this model soon. If I'm successful, I'll send you a note.
Sylvana
Hi, Richard I have left this problem on standby for now, but plan on continuing this model soon. If I'm successful, I'll send you a note. Sylvana
Posted: 10 years ago 11.05.2015, 14:35 GMT-4
Hi!
Have you solved it?I hava the same problem
Hi! Have you solved it?I hava the same problem
