How to call the sound speed in material in Global Definitions (Parameters)?
Dear all,
I would like to create a geometry which the dimension is dependent on the speed of sound. I try to set a dimension in terms of root.mod1.mat1.def.c; however, it does not work. Do you know how to call the speed of sound in COMSOL?
Thanks and best regards,
S.K.
1 Reply Last Post 12.04.2011, 02:18 GMT-4
Posted: 1 decade ago 12.04.2011, 02:18 GMT-4
accessing the material properties is slihtly tricky, and if you change something int he materials, there are a fair chance that your link will change too. So "my way" is to simply define a Parameter and copy the numerical value in there, it's easier to control
Hi accessing the material properties is slihtly tricky, and if you change something int he materials, there are a fair chance that your link will change too. So "my way" is to simply define a Parameter and copy the numerical value in there, it's easier to control -- Good luck Ivar
