Cluster-Computing with Comsol
Hi!
Im am trying to configure Comsol 4.1 for parallel computing on a number of nodes (currently 3) on a Scientific Linux System using PBS.
I found out i had to set up a mp-daemon on each of the nodes an tried like this:
>cat $PBS_NODEFILE|uniq > mpd.hosts % generating Hostfile
>comsol mpd boot -f mpd.hosts -n 3 -r ssh % starting mp-daemons
A quick check via "comsol mpd trace" gives back all 3 nodes, the mpds are running on, apparently communicating with each other one or the other way.
How to start comsol itself, however, i am not sure. I tried it with
>comsol
i.e. without any parameters, but the other nodes are not used. Another attempt with
>comsol -nn 3 -mpirsh ssh
seems to generate a few comsol tasks (at least on the one node i can see using htop) but does not provide a comsol-GUI, so no interactive testing or working is possible.
Can anyone help me on this matter?
Best regards, Christian
4 Replies Last Post 19.04.2013, 12:53 GMT-4
Posted: 1 decade ago 09.04.2011, 09:37 GMT-4
You need to also connect to a comsol server running on one of the nodes that is running mpi. Also be sure to enable "cluster computing" in your model solver tree. This is how I do it, but there are also other ways.
Posted: 1 decade ago 17.06.2011, 17:41 GMT-4
Well folks, I am looking for a little advise in getting my cluster up and running. I'm finding i can't get my mpd to load on any node except the head node. I've followed every step i can find and still it does nothing for me. I have mpd.hosts file in my home dir, populated with the names of the compute nodes i'm wanting to use. When I load
..</comsol mpd boot -f mpd.hosts -n 3 -r ssh i get the result of
..<totalnum=3 numhosts=1
..there are not enough hosts on which to start all processes
can anyone point me in the right direction?
Thanks for your time
Well folks, I am looking for a little advise in getting my cluster up and running. I'm finding i can't get my mpd to load on any node except the head node. I've followed every step i can find and still it does nothing for me. I have mpd.hosts file in my home dir, populated with the names of the compute nodes i'm wanting to use. When I load ..
Posted: 1 decade ago 11.08.2011, 19:23 GMT-4
I was having this same problem, but I got around it by using the full path to the mpd.hosts file
Posted: 1 decade ago 19.04.2013, 12:53 GMT-4
Thank you Ben Higgins, the full mpd.hosts filename did the trick. You solved a very frustrating problem for me!
