Tie constraint
Dear all,
In Abaqus there is a connection model called ''tie constraint''. Is there any equivalent to this connection type in COMSOL?
3 Replies Last Post 20.12.2017, 10:39 GMT-5
Posted: 7 years ago 20.12.2017, 05:02 GMT-5
By using an Identity Pair together with Continuity in the physics interface you will get an analogous coupling.
Henrik
Henrik Sönnerlind
COMSOL
By using an Identity Pair together with Continuity in the physics interface you will get an analogous coupling. Regards, Henrik
Posted: 7 years ago 20.12.2017, 05:57 GMT-5
Hi Henrik,
Thanks for your reply. In a paper, it was mentioned that they have used tie constraint to make a perfect bonding between shell and solid in ABAQUS. So, does it mean they have used identity pair and Continuity for shell-solid perfect connection?
Kind regards
Hi Henrik, Thanks for your reply. In a paper, it was mentioned that they have used tie constraint to make a perfect bonding between shell and solid in ABAQUS. So, does it mean they have used identity pair and Continuity for shell-solid perfect connection? Kind regards
Posted: 7 years ago 20.12.2017, 10:39 GMT-5
Hi Shaghayegh,
In that case, you should use a Solid-Shell Connection multiphysics coupling.
Henrik
Henrik Sönnerlind
COMSOL
Hi Shaghayegh, In that case, you should use a Solid-Shell Connection multiphysics coupling. Regards, Henrik
